#61 |
Got mine figured out as well! Only hiccup was that I had to use the blue wire (parking lights), which they label as "blank", to turn on the HIDs. For some reason, turning on the high beams was turning off the low beams (i.e. turning off the HIDs).
I will eventually put up the full wiring schematic with color codes, and pictures of my light output from the dual bi-xenon projectors with 55w HID kit. Even took some comparison pictures of 55w vs. 35w. Last edited by island boyeee; 07-17-12 at 09:21. |
#62 |
Moderator
That looks clean! I have no interest in this myself since it's law here that your headlights have to be on at all times but i'm glad you all found a way to do it and keep it looking OEM!
![]() "Faster we become, until the thrill of speed overcomes the fear of death"
#63 |
Did you wire the running lights into the switch? I still have to do that but I want to get the proper pins/sockets for the standard connectors first, but I can only find them in packs of 100 for about $10 each pack.
#64 |
I don't use parking lights in the front. I pulled the bulbs out shortly after I got the bike.
The tail and license plate lights still turn on with the ignition. Thought about at least tying the license plate light into the switch, but that's a project for next year. |
#65 | |
I use that kit and it rocks.
Street: Daytona 675se 2010 Bazzaz Z-Fi with Autotune, Cat GONE, EXUP GONE, Arrow Slip-On, Carbon Craft Tank Guard, BMC Street Air Filter, DID ERV520 with Driven Sprockets (-1/+2), C4U Carbon Hugger, C4U Carbon Front Fairing, FP Shorty Levers, Rizoma Rear Sets; Avio21 Indicators; Open Front Sprocket; Tomok Mirrors; Wheel Sliders; Grips and Bar-End Silders, Zero Gravity Corsa Smoke Windscreen, GB Kit, Ecliptech Twinlight Driver 3 Kit, ESP Alarm Track: Daytona 675 2008 ... in progress! |
#66 | |
I got these off ebay.uk for £40 shipped to the States. It's off a 2005 955i. Now I just need help wiring the thing. It's plug but not play. The bike will not start with it on and it only seems to work with the high beam. The low beam and parking lights stay on when the bike is on even thought the switch is in the off position. And I have no clue where the UK piggy tail would even wire to on the U.S. spec bikes. Any help would be much appreciated. ![]() ![]()
#67 |
Your controls+plugs look the same as the ones I bought, You have to move the clutch switch over to the new controls, and ditch the piggy back. I posted the original wiring schematic here http://www.triumph675.net/forum/showthread.php?t=63957, my memory is fuzzy on the new wiring to accommodate turning off the lights and Im away from my bike atm...
Update: By default the lights would be on even with the controls not plugged in because the headlight wiring bypasses the switch, I had to cut one of the wires going to the headlights and wire it through the controls. Have a look at the haynes manual for a full schematic. Last edited by jimmytb; 12-12-12 at 07:45. |
#68 |
Should've just gotten the K&S Tech assembly...
I still have all my wiring written down and pictures of my install. I should put those up some day
#69 |
Thanks for the help Jimmy!
I'm gnna get crackin' at this once I'm finished with my shift.
#70 |
