#11 |
edited
#12 |
I'm not so sure if it's the RR that went bad. Other people with bad RRs report their batteries got drained. My bike just doesn't do that. I started up 3 times no problem after I shut it down.
I'm hesitant to take it back out cause I don't want it to die on me in traffic again. All of a sudden when I'm riding the rev just goes crazy. No power then goes up to 7-8k rpm and then no power and then goes to 7k rpm and then no power and then goes back to high rpms. After that it just lose all power to the rearwheel no matter how much throttle I give it and I have to coast to a stop then the engine shuts off when the bike is stopped. I'll check the voltage tomorrow and see if it's something electrical. Last edited by nixthewiz; 12-09-12 at 14:47. |
#13 | |
![]() Join Date: Jan 2009
Not sure if the R/R is the problem in your case as the symptoms seems different to those usually reported on here, but for peace of mind I'd find out for sure if the R/R has been replaced with the MOSFET unit. Quick and easy to do if you check out my photo. |
#14 | |
The previous owner said the RR got replaced because of the recall. He got it done early october. |
#15 | |
#16 |
#17 |
Excellent. Hopefully you can forget about that now. Good luck.
#18 |
So today I took the power commander off the bike then went for a test ride. The bike ran well for the first 20 minutes or so. Then as I accelerate from low RPMs to 4-4.5k RPM the rev start increasing and decreasing by itself again. The oscillation is a lot quicker than before. As I get to 5K RPM the jerking stops.
The engine doesn't stall however. Maybe I just need to reflash a new map for aftermarket exhausts? The ECU is still running an old stock map, I have a Jardine slip on on the bike. |
#19 |
Site Sponsor
When my regulator failed I installed a Rick's Motorsports Hot Shot regulator and have had no problems since. Been about a year or two since I installed this. Before my regulator went bad on my 2007 I had a different issue with the pickup coil on my stator and also had that replaced. Lately no problems.
I would try using the Arrow/Triumph slip on tune from your Triumph dealer for the Jardine slip-ons. This should make it run correctly. |
#20 | |
