What did you do to your Street Triple today? - Page 299 - Triumph675.Net Forums
Old 12-11-12, 04:00   #2981
Nice work ZR
2010 TornadoRed D675
Old 12-11-12, 04:06   #2982
ZrexRich
ZrexRich's Avatar
Thanks!
Old 12-11-12, 15:20   #2983
e rock
e rock's Avatar
ZrexRich, what map are you running w/those DanMotos?
Old 12-12-12, 01:43   #2984
ZrexRich
ZrexRich's Avatar
I'm still running the stock map. I'm also using two db killers in each muffler as they were still to loud for my liking(I work swing shift and don't get home untill after 10PM). I will probably try a different map when I install some Daytona cams at the 12K service.
Old 12-12-12, 06:48   #2985
Orangeman
Orangeman's Avatar
Probably ??????? try MUST..... and it will require a custom map....
... My Bike
Old 12-12-12, 17:13   #2986
Johnnystriple
Johnnystriple's Avatar
Great write up. I just checked to make sure my tender was still working.
Old 12-17-12, 18:48   #2987
f4nm4n
f4nm4n's Avatar
Cleaned out an area of my barn to store the bike for the winter. Got her mostly sorted but will have some work to do once the christmas gifts roll in. First winter with my first bike... added fuel stabilizer then put it up on stands. Removed the seat and put the battery on a tender. cleaned and lubed the chain. Anything else i missed? Canadian winter btw.
Old 12-17-12, 19:50   #2988
Did you change the oil? You don't want to let used oil sit in it for too long. It's nasty stuff.
Trinity's Mod Thread
Old 12-17-12, 20:53   #2989
GuiltySparc
GuiltySparc's Avatar
Might also want to cover up openings like the exhaust if you're out in mouse country.
2010 Ninja 250R
2012 Street Triple R
Old 12-17-12, 20:53   #2990
f4nm4n
f4nm4n's Avatar
Didnt change the oil. Was going to change it in spring before next season, guess its better to do it now and let it sit? didnt know if oil degraded over time so would be a waste changing it before storing. Thanks for the tip :) something to get done this weekend.
