#11 |
![]() Join Date: Mar 2011
MacB, you know I love you man but lack of usable adjustment is a symptom of a long soft top out spring because you use up most of your pre-load adjustment range just compressing the top out spring and very little of it's range actually adding pre-load to the main spring.
Dave Moss explaines it better, long, but better... http://www.ustream.tv/recorded/6349484 . |
#12 |
Sorry I didn't mean to say it was one way or another. I was really trying to make it clear that the answer is not to add more preload to set your sag. Also I can assure you my 09 does not have a long top out spring as my preload adjustment responds almost directly to my sag numbers. So I'm betting there is either a lot of changes over time or that the spring rates they use for top out and main spring aren't very good and aren't always to the rated spec. I actually predict the latter is the most likely since this occurs on most brands.
#13 | |
I'm getting 35mm fork sag with no lines showing, preload is fully screwed in. Previously with my Daytona, I had about 4 lines showing with 35mm sag. I forget the source but I recall reading that the spring rates on the Daytonas were stiffer compared to the StR and my feeling is the springs are softer and more suited to my weight. Does that sound right?
Ed |
#14 |
I have an '09 STR. 180lbs 3 lines showing 30mm sag. So with 4 lines that could be right. You said you had the preload screwed all the way in.
#15 |
Daytona spring rates are a lot stiffer than the R.
#16 |
Sorry reading comprehension test failed. I overread the Daytona part with 4 lines.
So yes your STR is significantly different then mine. |
#17 | |
Ed |
#18 |
Suspension setup is all dependant to the rider. Its not a universal thing. As you get faster your suspension setting will change as well. What you have one weekend may feel way different the next weekend. I know when i started riding on the track after about my third track day i was changing settings on my street bike. It is also dependant upon weather. As it gets colder or warmer your suspension will soften or stiffen because of the change of density of the oil. (Becomes more fluid when warm) i am personally running a set of gold valves in my front forks with olhins oil and springs for my weight and a 602 olhins rear shock. Works pretty well.
#19 | |
What works for one rider may not work for another. There's no single, magic set-up. However, the common element of control would be a bike with stock suspension which probably describes a fair number of bikes on this forum. The point of sharing info here allows us to establish a baseline set-up from which to start. From there, we can fine tune our set-up and/or modify our suspension to best suit us individually. It's safe to say, we're able to benefit from each others knowledge, trials and errors.
Ed |
#20 | |
