Heat Exchanger to Oil Cooler - Page 2 - Triumph675.Net Forums
Go Back   Triumph675.Net Forums > Marketplace forums > UK and Europe Vendors
UK and Europe Vendors Forum for UK and Europe-based Vendors and Triumph dealers to post their info. READ the rules before posting please
Old 12-04-12, 22:02   #11
sittingturbo
sittingturbo's Avatar
Originally Posted by shouldnthave View Post
I'm positive it's happening right now Rink... Get to the garage!
LOL, hope it doesnt happen tonight while I sleep...
Old 12-04-12, 22:25   #12
shouldnthave
shouldnthave's Avatar
It's best to stay vigilant! That's why I sleep with the old girl every night. The GF got upset at first, but I told her: "we only have room for 3 motorcycles, two people, and one dog in this bed. Are you really going to make me buy a new bike?"
She has been ok with it since. Jebus knows I'm not getting another dog....
675R dedicated track bike
My BOTM thread.
Old 12-05-12, 07:40   #13
Triumph Race Support
Site Sponsor
Triumph Race Support's Avatar
RRP of the oil cooler is £945.00!
The stock heat exchanger is £300.
The add on radiator which is water only is £673.00
They will be available from Friday to order from www.ukracesupport.co.uk
Old 12-05-12, 14:45   #14
Zupe
Zupe's Avatar
Default oil cooler
Hi Si,
surely looks like a quality piece.
Mine is rather samekind, but made by some R&D guys at BSS paddoc ,during sat-sun night ,I suppose.
It uses KTM fabricated radia and oilhoses are a lot of longer, surrounding the engine.
The other good point I`ve found out in addition to increased reliability of lubrication, is notably decreased engine temperature. Extra radia&oilcapacity achieve 5to10 degrees lower enginetemp according my experience.
timo
Old 12-06-12, 03:10   #15
Rink675
Rink675's Avatar
lol that's funny! I used to think drag racing cars was expensive.....no bikes are worse!
2007 Triumph 675 Race Bike
Old 12-12-12, 01:14   #16
homer
homer's Avatar
Send a message via AIM to homer Send a message via Skype™ to homer
I've been looking for something like this for quite some time.
Where do you connect the oil feed and return lines? Do you have to use a sandwich adapter? Or is there an extra provision for an oil feed in the block near the filter? If that's the case, where does the return go?
Have you been monitoring oil temps with this setup? What sort of temperatures did you have before the cooler was installed, compared to the temperatures after was installed?
Moreover, do you have any idea what sort of temperature drop there is across the heat exchanger?
Thanks!
Old 12-12-12, 04:09   #17
Site Sponsor
Thanks!
The heat exchanger is removed and replaced by the round silver manifold in the picture. Everything to do the job is in the picture except blanks for the two water hoses that are no longer needed when the heat exchanger is removed.
As Zupe said you can see a big difference in water temp when using one of these. Not had a seperate temp gauge on the bikes but on the stock clocks its 2 bars less than it was!
Old 12-13-12, 15:05   #18
homer
homer's Avatar
Thanks for the extra info! I see how it connects now. I didn't see the adapter in this picture when I wrote my first post because I was on my phone.
Now that I'm thinking about it, that adapter is probably the best overall solution for an oil cooler on our bikes because it replaces the factory heat exchanger. If an external cooler is plumbed in anywhere else, either using a sandwich adapter or one of the fittings in the block, it will work OK, but the factory heat exchanger will still be there working against it.
