[Track] Really fast corners and throttle... - Page 2 - Triumph675.Net Forums
Go Back   Triumph675.Net Forums > Daytona 675 & Street Triple 675 Global Forums > Riding Skills
Riding Skills Tips, lessons, experiences, etc. Beginner, intermediate and advanced.
Old 11-22-12, 16:33   #11
sittingturbo
sittingturbo's Avatar
Originally Posted by Rink675 View Post
I don't know if it's "wrong" to add throttle and lean at the same time but it is the most common reasons for crashes. I have done it on accident when I was first learning throttle control and never crashed but it was on mild street riding and I wasn't in the high RPM range either so it would make it more difficult for the rear to spin up on me.
I think at some point you are either maintenance throttle while leaning or slightly rolling on because if you have a decreasing radius turn and you have to tighten up your line the throttle still needs to be there to keep the suspension working properly.
Just my thoughts on that anyway.....could be wrong.
With experience and properly set up bike, you can get on the throttle quite aggressively while leaned over. It is a feel thing, you need to be able to feel when its starting to spin up or step out on you. So much of this discussion is a mute issue, because every turn is different, so without us all discussing a specific turn at a specific track, we will all be on different pages.
Old 11-22-12, 18:26   #12
Rink675
Rink675's Avatar
Ah ok, I just never wanted to test the limits of it on the street.
2007 Triumph 675 Race Bike
Old 11-28-12, 23:01   #13
Red October
Red October's Avatar
A rule of thumb our instructors teach here is (assuming good sticky surface on a nice warm day and neutral camber):
If your knee is just touching, you can get to WOT using 1-2-3 count.
If your knee is firmly planted, use 1-2-3-4-5 to get to WOT.
The rest is feel.
Old 11-29-12, 19:49   #14
Ricardo_
Ricardo_'s Avatar
touching the tarmac?
firmly planted on the asphalt?
Old 11-29-12, 22:00   #15
Smoke
Smoke's Avatar
Maintenance throttle = the throttle you need to keep your speed from varying
You can try a bit of rear brake, among the other techniques discussed. Of course, some will tell you the rear brake is useless
Old 11-29-12, 22:14   #16
Red October
touching: put knee down, feel the ground, pull it back up.
Firmly: if you can't really pull it up
Old 11-30-12, 05:41   #17
Ricardo_
Ricardo_'s Avatar
but what to do with throttle application before attack the fast corner, wich demands full lean?
i think rolling off a little bit and then steady/maintenance is the winner.
Old 12-02-12, 23:45   #18
Red October
Trail brake, then start rolling on, using the "once the throttle is cracked open..." rule, until you have desired direction, then 1-2-3?
Old 12-03-12, 10:46   #19
lokodog
I can see how this would be different at each track. At Fontana Speedway there is turn 2 and a little sweeper between turn 4 and 5 ( I don't think it has a number). Entry speed is slow into those corners because you're just coming out of another corner, but you can move pretty good in those corners midway through. I just pin it and pray! She likes to dance between shifts. I'm pretty sure that's not the right way of doing it though and im not very quick.
Sent from my DROID2 using Motorcycle.com Free App
US triumph675.net Lap Time Leader Board: https://docs.google.com/spreadsheet/...4aFJobWc#gid=0
2007 Graphite 675 (stock)
Dunlop Q2's
Times
Fontana: 1:47.467
Chuckwalla: Nothing yet
Big Willow: Nothing yet
Streets Willow: Nothing yet
Old 12-03-12, 18:28   #20
TonyNyc
TonyNyc's Avatar
Word.
