The Definitive 675 Charging Diagnostic/Upgrade Thread - Page 84 - Triumph675.Net Forums
Old 10-17-12, 18:20   #831
momostallion
something in 07 d675 died (~6k miles) i had a new battery and mosfet RR sitting around so i decided i would finally do this install.
while i testing my stator, i get a beep (or continuity) when testing resistance from any stator wire to ground so i take it my stator is done for.
i decided to stop by the dealer today to get a quote and he looked up my vin#. my 2007 was covered under warranty for RR so i guess that's neat. i'm still SOL on the stator which was $450 or something around there.
i think im going to put the bike back together enough to test the stator's output voltage while running.
Old 10-17-12, 20:32   #832
momostallion
here are my numbers:
Record your battery voltage under the follow conditions
1) Ignition off, unloaded battery. 12.58 V
2) Ignition on, headlights on, not running 12.36 V (no headlight hooked up right now)
3) Bike started, running at idle 12.1 V at idle. 12.3 V @ 4k RPM
Rectifier/Regulator
With your meter set to read resistance (use a diode test if the your multi-meter has one), test from each pin of the three pin plug, to both the black/red (positive) & black/white (negative) wired pins of the 4-pin plug
i didnt really get this step:
stator pin 1 to RR red pin 1 -0.L, RR red pin 2 - 0.L, RR black pin 1 - 9.6 mOhm, rr black pin 2 - 9.6 mOhm
stator pin 2 to RR red pin 1 -0.L, RR red pin 2 - 0.L, RR black pin 1 - 10 mOhm, rr black pin 2 - 10 mOhm
stator pin 3 to RR red pin 1 -0.L, RR red pin 2 - 0.L, RR black pin 1 - 10.9 mOhm, rr black pin 2 - 10.9 mOhm
Stator Test
Measure between the three respective combinations of the three pins:
1-2 0.5 ohm
2-3 0.5 ohm
3-1 0.5 ohm
check from any one pin to the engine ground terminal:
1.3 ohms :(
voltage output test of the stator with engine running:
1-2 2.5 V idle | 2.5 V @ 4k RPM
2-3 4.7 V idle | 14 V @ 4k RPM
3-1 4.6 V idle | 12.7 V @ 4k RPM
Old 10-17-12, 21:23   #833
momostallion
pulled the stator. i guess ricks is the best option for fair price replacement?
IMG_0053 by momostallion, on Flickr
IMG_0052 by momostallion, on Flickr
Old 12-01-12, 09:09   #834
Bamboo671
Bamboo671's Avatar
Send a message via Skype™ to Bamboo671
So we know that the FH012AA R/R works but they have been replaced it with a newer model, FH020AA. Think I would have any issues using it? Also, does anyone know where I can get the wiring kit from. My current FH008 R/R is good but the connectors are fried as well as the fuse. Looking to get a new R/R if I can't find the wiring kit and connectors.
1997 YZF100R/Thunderace - 12 o'clocked it!
2008 Jet Black Daytona 675 - I called her Tasi!...she's dead!
2013 Daytona 675R - Her name is Tasa!
Old 12-02-12, 16:14   #835
kevinoneill
Default Test results interpretation
Results below. But short back story. Bike didn't start 1 day, i thought I had seen the flickering dash which I read was an indication of the faulty R/R. So I cursed a few times. Did all the checks, results below. And it appeared the Regulator was giving bad results (i think, please see my question below).
So I decided to start it up for no real reason, confident it wouldn't. And with the Regulator disconnected it started. So I reconnected it, and it still started up. WTF??
I don't understand, I don't know if maybe a faulty connection? And disconnecting and reconnecting smoothed it out? Maybe it was extra cold the few days I tried to start it a few weeks back when it didn't start and it was grumpy? Little baffled. Any thoughts?
Battery
Ignition off 13.08V
Iginition on, high beams on 12.37V
Running (very suprised it started, read on) 14.5V
Stator
All read 0.2 Ohms
Checked against the engine ground, all read ZERO
R/R
Results vary pending which way i run leads. I don't know what this means.
Using the RED on the 3 Pins, the 2 BLACK on the 4pin read ZERO
Using the BLACK on the 3 Pins, the 2 RED on the 4pin read ZERO
Old 12-02-12, 17:51   #836
Bamboo671
Bamboo671's Avatar
^^^^ You should read some sort of resistance when you run the test. Reading a short means the R/R is bad.
Old 12-02-12, 18:33   #837
kevinoneill
Is it normal to read the shorts on different wires pending which way I route them?
Old 12-02-12, 23:57   #838
Why are you bothering to test it. You have the old unit which is recalled. Take it to a dealer and they'll replace it for free.
Old 12-03-12, 12:15   #839
kevinoneill
Dealer is 1.5 hours away, needs the bike in person, and before yesterday the bike didn't start. I did look into that. Must be dealer installed.
So if I can fix this myself in person, I'd rather not spend the money to tow it, or potentially risk having it not start for me 1.5 hours away, if there is another potential issue beyond the R/R...
Can it be confirmed my R/R is dead from the results I posted? The steps outlined confused me a little, all 4 wires should have some resistance?, in my case 2 did not, and even though the 2 that did not seemed to flip pending which way I ran the leads... this doesn't matter, the R/R is dead and needs replacing?
Old 12-03-12, 12:46   #840
Let me clarify one point for you. The bike is not dependent on the charging system to start. As long as it has a good battery the bike will start and run with or without the charging system. So if it didn't start and then did start later without you charging the battery in between then the issue isn't the charging system.
As for getting it to a dealer a lot of insurance policies have road side assistance which would cover the cost of getting it to a dealer.
