'12 d675R what year 150 throttle tube?? - Triumph675.Net Forums
Old 11-28-12, 10:29   #1
Swift_R
Default '12 d675R what year 150 throttle tube??
Sorry if it's a repost my search function is not working >:O
I have a '12 Daytona 675R im looking to do 1050 throttle tube on it. im curious if they changed at all through the years? Any idea what years will fit?
Also i know it is a bit fatter? What grips will fit if?
Thanks!
Darrel
Old 11-29-12, 01:05   #2
Any of the Speed Triple 1050 throttle tubes will work. There have been no changes for the 1050 or 675 throttle tube. The throttle tube is the exact same size as the one on the Daytona and every other bike made so no need for different grips.
Old 11-29-12, 13:01   #3
MakinBeer
MakinBeer's Avatar
Related question: I was told that the 1050 tube wouldn't work with the 2012's revised throttle mapping, which makes no sense to me. Confirm/deny? The sales guy told me yes (he has an older Daytona), like three people at the parts counter told me no. It seems to me it would be the same as if I grabbed a whole bunch of throttle, just with less total movement.
Also, how much does this alter cable positioning/routing?
Old 11-29-12, 13:33   #4
All 675s received the same throttle mapping with the latest map updates.
You have to readjust the cable free play but no rerouting necessary.
Old 11-29-12, 13:49   #5
MakinBeer
MakinBeer's Avatar
Thanks. I'll have to go back and call shenanigans. Even the sales guy said 2012s have a non-linear/softer/progressive throttle mapping.
Old 11-29-12, 13:58   #6
They made a big deal about the new throttle mapping in the press releases but didn't say a thing about the new maps they released for all the other bikes at the same time other then that they were for ethanol fuel. One of the details of the new maps though was that it contained the same throttle smoothing, rpm matching on down shift and other throttle related features that the 2012 models received.
The new completely new 2013 models however do have completely different throttle cams and mapping that will not be applied to older bikes.
Old 11-30-12, 09:54   #7
Swift_R
I ended up ordering the tube for an 09 speed tripple ill let u know how it works after Christmas when i install it :)
Old 11-30-12, 11:50   #8
As long as its a 1050 Speed then it will work fine.
