| Riding Skills Tips, lessons, experiences, etc. Beginner, intermediate and advanced. |
#11 | |
#12 | |
Ah ok, I just never wanted to test the limits of it on the street.
![]() 2007 Triumph 675 Race Bike |
#13 | |
If your knee is just touching, you can get to WOT using 1-2-3 count. If your knee is firmly planted, use 1-2-3-4-5 to get to WOT. The rest is feel. |
#14 |
touching the tarmac?
firmly planted on the asphalt? |
#15 |
Maintenance throttle = the throttle you need to keep your speed from varying
![]() You can try a bit of rear brake, among the other techniques discussed. Of course, some will tell you the rear brake is useless
The slower you move, the more dangerous your bike is... I'll let you work out the conclusion from there ![]() If you find wearing proper gear's too hot, you're just not fast enough ! ![]() Dual Desert Eagle EBB ? MER IL ET FOU ! Viendez nolifer avec nous sur le salon #Airsoft sur IRC ! Et jouer avec Ploubalairsoft entre le 22 et le 35
#16 |
#17 |
but what to do with throttle application before attack the fast corner, wich demands full lean?
i think rolling off a little bit and then steady/maintenance is the winner. |
#18 |
Trail brake, then start rolling on, using the "once the throttle is cracked open..." rule, until you have desired direction, then 1-2-3?
#19 |
I can see how this would be different at each track. At Fontana Speedway there is turn 2 and a little sweeper between turn 4 and 5 ( I don't think it has a number). Entry speed is slow into those corners because you're just coming out of another corner, but you can move pretty good in those corners midway through. I just pin it and pray! She likes to dance between shifts. I'm pretty sure that's not the right way of doing it though and im not very quick.
Sent from my DROID2 using Motorcycle.com Free App
US triumph675.net Lap Time Leader Board: https://docs.google.com/spreadsheet/...4aFJobWc#gid=0 2007 Graphite 675 (stock) Dunlop Q2's Times Fontana: 1:47.467 Chuckwalla: Nothing yet Big Willow: Nothing yet Streets Willow: Nothing yet Last edited by lokodog; 12-03-12 at 11:43. |
#20 | |
