Need 1/2" drop - Page 2 - Triumph675.Net Forums
post #11 of 25 Old 11-23-12, 06:03
Bhodi513
Bhodi513's Avatar
Wouldn't having a passenger drop the bike a bit more?
AB
2012 Daytona 675R
2005 Bonneville
2002 WR250F
1971 T120
Bhodi513 is offline
post #12 of 25 Old 11-23-12, 06:18
!!675R!!
!!675R!!'s Avatar
AB
I wouldnt ride with a passenger if you cant even have your toes on the ground bottom line, but thats just me.
2013 Triumph Daytona 675R
!!675R!! is offline
post #13 of 25 Old 11-23-12, 06:54
Bhodi513
Bhodi513's Avatar
Originally Posted by aussieak View Post
I'm short as well 5.5Ft I shaved the original seat got 20mm off it, its still to tall for me but. I am not on tip toes any more.
Confused the OP with Aussieak's response. Yeah if you can't tip toe, I wouldn't suggest a passenger at all. I can flat foot it and some people make me nervous because they aren't good passengers.
AB
2012 Daytona 675R
2005 Bonneville
2002 WR250F
1971 T120
Bhodi513 is offline
post #14 of 25 Old 11-23-12, 15:22
Dave73
Dave73's Avatar
Its your bike. If you want to drop it half an inch do it, just keep your stock parts as spares.
Im guessing if you that tall you don't weigh much. You should probably invest in the correct spring first, adjust your sag, then see how it feels.
06 675 Track Bike
10 Tiger 1050 Everything Else Bike
Dave73 is offline
post #15 of 25 Old 11-24-12, 02:25
stickem189
stickem189's Avatar
Plus 1 on what Dave said. Adjust the suspension first. Might give you enough to feel more comfortable.
Sent from my Motorola RAZR MAXX using Motorcycle.com Free App
stickem189 is offline
post #16 of 25 Old 11-28-12, 22:38
wfire19
wfire19's Avatar
Yeah im 5'8" and could hardly tip-toe the bike to begin with, fiddled with the suspension a little, according to the manual. softened it up a little. It helped me get to being on the balls of my feet so i was alot more stable. Being only 150ish the stock setup was too hard for me. I would agree looking at suspension setup before looking at lowering the bike
wfire19 is offline
post #17 of 25 Old 11-28-12, 23:29
JRage
JRage's Avatar
im 5'6 with 30 inch inseam on the r suspension and i can get both balls of my feet down thanks to me being fat but can no way flat foot. just something you have to get used to.
JRage is offline
post #18 of 25 Old 11-29-12, 03:23
ScotiC
ScotiC's Avatar
I bought a d675 with a psr lowering link on it as the chick that owned is was about 5'3". The front was adjusted as well- not sure about the specifics. I've since swapped it for stock as I dont need it. If interested I'll sell mine to you if you decide to go that route.
ScotiC is offline
post #19 of 25 Old 12-02-12, 13:57
mikewitki
mikewitki's Avatar
I'm 6'1 and can easily flat foot on both sides, but i have realized that in just about every scenario i still choose to to use the balls of my feet instead. Maybe because of better feedback from the road/bike and then i will have a faster reaction time just in case. Just something to think about and that way you don't compromise the bikes geometry. Grass isn't always greener on the other side!
All though i do completely understand wanting to be flat footed with a passenger. Flat footed does provide more stability with the extra weight no doubt.
-2011 Daytona 675-
Jardine RT-1 Slip on - GB Protection Bundle - Cox Radiator Guard - GP Rear brake Fluid Reservoir - Carbon Fiber Tank Pad - 1050 Throttle tube - Comp Werks Integrated Taillight - Tail Tidy -
mikewitki is offline
post #20 of 25 Old 12-02-12, 14:30
sittingturbo
sittingturbo's Avatar
I would spring the bike to your correct weight, then shave the crap out of your seat. I am about 5'4" and 3/4 of an inch... Don't forget the 3/4"...
I can not flat foot at all... Only one foot at a time, and I have no issues, other then backing up.
sittingturbo is offline
