Cel after my daytona rear swap - Triumph675.Net Forums
Go Back   Triumph675.Net Forums > Daytona 675 & Street Triple 675 Global Forums > Modifications > All Things Tuning
Old 11-27-12, 17:49   #1
Tst
Tst's Avatar
Default Cel after my daytona rear swap
So, now that my street has the Daytona rear end, when i turn the bike over, the CEL is on. Bike doesn't appeAr to hesitate but it is hella cold out. Could it be that the ambient temp sensor is messing with it? I had 2 bro exhaust on the bike and the TOR tune, could it be that its now the tune playing up? I just don't want the swap to cause any damage is all. Thanks in advance
Old 11-28-12, 00:31   #2
Dave73
Dave73's Avatar
The baro sensor was in the tail..my guess is something isint right with that....
09 Street Triple
06 Track Triple
Old 11-28-12, 09:26   #3
DecepticonDon
BOTM Marshall
DecepticonDon's Avatar
Have you downloaded TuneECU? check the code.
Dave, the baro sensor on the Daytona's are in the nose cowl, and in the tail on Striples.
it's in the tail on my bike since removing the nose cowl.....no probs
doesn't matter where they're located, as the pressure won't be noticeably different
Download TuneECU FREE!!! Click here...
"Constantly choosing the lesser of two evils is still choosing evil." - Jerry Garcia
Old 11-28-12, 10:27   #4
Dave73
Dave73's Avatar
Yep... I just zip tied mine on to something back there
09 Street Triple
06 Track Triple
Old 11-28-12, 11:17   #5
Tst
Tst's Avatar
Decepticon, its under the seat. Im hoping its cuz of the TOR tune on a stock daytona can. Hope to remedy that when i can unload the str3 exhaust and get one for the daytona.
Old 11-28-12, 11:34   #6
Disrupt
Disrupt's Avatar
Deff check the code it could be a number of things. Did you remove the exup from the exhaust?
1993 Mitsubishi 3000GT VR-4
2007 D675
Old 11-28-12, 11:57   #7
Tst
Tst's Avatar
Exup? If i gotta ask prob not. What is it, where, and why would i need to take it off? Thanks.
Old 11-28-12, 12:13   #8
Disrupt
Disrupt's Avatar
In short its an exhaust valve that opens and closes to regulate noise at idle. The valve is known to get stuck open or closed which would throw a code, but now I am confused did you start with a daytona or a striple? the striple did not come with it. So if you have a striple then its something else.
Edit: NVM you are originally a Streety, the TOR tune shouldnt be a problem here since several people have ran TOR tune on a stock setup. It is not optimal and usually people will upload the tune while they are waiting on their slip on to arrive.
2007 D675
Old 11-28-12, 12:21   #9
Tst
Tst's Avatar
Ok, so then valve is not an issue. Cool. Im hoping its just cuz of the cold ass weather. Did not disconnect anything that didn't need to b during the swap. And what i did disconnect i connected again.
Old 11-28-12, 12:25   #10
Disrupt
Disrupt's Avatar
You might have to double check some hoses and wires, sometimes the most obvious thing is causing the problem. But hopefully when you pull the code you can confirm the issue.
2007 D675
