Safety Wiring - Triumph675.Net Forums
General Racing Discussions Discussion area for any non 675 related racing (Moto GP, World Superbike, etc) & general race set up / questions.
post #1 of 12 Old 11-20-12, 22:29 Thread Starter
ScotiC
ScotiC's Avatar
Safety Wiring
So I'd like to prep my bike to try my hand at racing. I don't have a drill press or have access to one. Can anyone tell me if there are kits for predrilled bolts and the sort?
ScotiC is offline
post #2 of 12 Old 11-20-12, 22:57
dubguy85
yoyodyne sells them, pro bolt sells them.
dubguy85 is offline
post #3 of 12 Old 11-21-12, 00:05
old blue
old blue's Avatar
There are pre-drilled sets out there, but to do it on the cheap you'll probably manage with just a vice, a cordless drill and some patience. That's how I did it.
Mind you, you'll need fresh, sharp drill bits if you start working on stainless, but it can be done.
O.B
old blue is offline
post #4 of 12 Old 11-21-12, 02:42
Rink675
Rink675's Avatar
O.B
I just assumed everyone did it this way! lol
2007 Triumph 675 Race Bike
Rink675 is offline
post #5 of 12 Old 11-21-12, 22:11 Thread Starter
ScotiC
ScotiC's Avatar
Thanks guys. I contacted pro nuts and it looks like its best to come up with a precise list of the bolts needing holes- otherwise it's cost prohibitive for me. Looks like I've got some homework to do. However- if anyone has a list then I'd gladly take that- cheers!
ScotiC is offline
post #6 of 12 Old 11-22-12, 00:08
Rink675
Rink675's Avatar
Incase you decide to do it yourself.
Rink675 is offline
post #7 of 12 Old 11-27-12, 14:18
ttilghman
you can get a drill press at sears for under and around $100. if you're racing, you're gonna need one...you'll never stop safety wiring new bolts/nuts/covers/etc. use cobalt bits and buy twice as many as you think you'll need. doing it with a hand drill is OK in the pits when you have no options, but to drill an entire bike you'll spend as much in broken bits as you would a press...especially when drilling adjacent faces on a hex.
ttilghman is offline
post #8 of 12 Old 11-27-12, 18:53
tooblekain
tooblekain's Avatar
Send a message via AIM to tooblekain
+1 on cobalt bits. Also be sure to get cutting oil and a spring loaded punch to make a divot/dot for where you want to drill. Doing this will prevent the drill bit from walking.
Ride and get shacked in the Tube....Kain the Throttle
What is The Clymb? Click on the link below and be prepared to be hooked:
https://www.theclymb.com/invite-from/tooblekain
tooblekain is offline
post #9 of 12 Old 11-28-12, 00:49
shouldnthave
BOTY Winner
shouldnthave's Avatar
+1
I strongly *shakes fist* recommend "Tap Magic" for the cutting oil.
675R dedicated track bike.
My Girl: http://www.triumph675.net/forum/showthread.php?t=76881
shouldnthave is offline
post #10 of 12 Old 11-28-12, 05:06 Thread Starter
ScotiC
ScotiC's Avatar
Copy! Drill press with lots of cobalt bits and some Tap Magic. I thought I'd just buy some predrilled bolts but I'm thinking I'll be way ahead by doing it myself in the long run. Thanks for the advice.
ScotiC is offline
