#11 |
Check that the suspension dogbone hasn't been changed, also the preload, compression and rebound might be off. have you set these on your new shocks?
Are the forks poking out of the top triple clamp the amount as on the other bike?
#12 | |
Preload, comp and rebound have all been set up on the new shock for my weight. Forks started out poking out the top by 4mm (as per manual) and are now at 8mm (same as other bike) to try get a more aggressive turn in.. no luck. Thanks :)
Project Digital Freelance Website Design & Development http://www.projectdigital.co.nz |
#13 |
What exactly feels different about his bike? more stable or something?
I wonder if the wheels could be the difference, if the suspension geometry is correct then the only thing that is left are the tires and wheels.
#14 |
were the front forks rebuilt? Its on my to do list to change the fluid and fluid level, it apparently makes a huge difference compared to the stock shit settings.
1993 Mitsubishi 3000GT VR-4 2007 D675
#15 |
Have you checked to see if the stock spacer was removed from the upper clevis where it connects the the frame? Its the Upside down U shaped thing where the rear shock connects to the frame. There should be a spacer in there.
#16 |
BULLSHIT.....we all know that red daytonas have more horsepower and speed, they all handle the same except for those freakish AARRRRR's
But we of the white/blue category definitely have the looks department cornered.
2007 SV650S -RIP suziQ 2010 Daytona 675SE -I miss my SV, but damn that daytona! 1980 Honda cm200t (running work in progress) |
#17 |
I could be wrong, but i think there is some adjustment to be made in the wheel base. You can stretch it out a little bit if you fit a longer chain and move the wheel back a little on the swing arm. That could be something to atleast check on.
3>4? Thats right, you heard me. 07 Graphite D675: Full Ti Remus exhaust, Full Arrow/Remus Hybrid tune, Rizoma Sportlines/Bar ends/ Fluid Tanks, ASV Shorty Levers, CF Infill Panels, CF tank pad, CF heat shield, CF Front fender, CF lower chain guard, CA integrated light, Watsens 10LED front indicator, Gel Seats front and back, CW fender eliminator.
#18 |
Forks 7.8mm above triple? That makes the bike very twitchy and nervous turning into corners.
Most people flush the forks with triple to gain more trail, especially pre-09 models. |
#19 | |||||
Thanks for all your comments guys! I'm sure I'll get there in the end.... hopefully!
#20 |
you didnt notice that the bike was lowered FOUR inches? i dont think my daytona could make it down the street if i lowered it four inches.
2012 Triumph Daytona 675R Arrow Slip On - GB Racing Slider Covers LSL Frame Sliders -Zero Gravity Corsa 6000k HIDs - LED Markers - TechSpec Snakeskins GB Racing Stator Cover(slight scuff) $50-retail is $70! price INCLUDES shipping, PM Me!
