WTB Front Brake Caliper for 09 675 Daytona - Triumph675.Net Forums
Go Back   Triumph675.Net Forums > Marketplace forums > Classifieds > Want To Buy
Want To Buy Ask for something you want, maybe somebody has it
Old 11-25-12, 14:16   #1
thejuiceman
thejuiceman's Avatar
Default WTB Front Brake Caliper for 09 675 Daytona
Looking for a front brake caliper(s) for my 09 675. Really only need one side but would buy in pair or even all three if the price was right.
This is for my street bike so it's parked until I find something so please help a brother out.
$10 Bird Dog Fee paid to whoever turns me on to one, IF I buy it.
Thanks guys (& gals)!
Old 11-25-12, 15:57   #2
Get R6 calipers. Cheaper, more common, no drag issue.
Old 11-25-12, 21:54   #3
thejuiceman
Do they bolt right on or require modification?
I am hearing conflicting things and I'm not a modification kind a guy. I'm lucky to put air in my tires by myself. Ok that's a stretch but not by much.
Old 11-25-12, 23:16   #4
If you can put on new 675 calipers, you can put on R6 calipers. R6's have slightly larger discs so it's a good idea to use spacers, but that doesn't make them any more difficult to put on.
Old 11-26-12, 00:02   #5
thejuiceman
Thanks for the info. Do you happen to have a link for the spacers your talking about and/or how to do it?
Old 11-26-12, 01:07   #6
I don't think anyone makes "official" spacers, but you only need to get them about 1mm further out. A washer or two would be good enough, just as long as the disc doesn't rub on the caliper body.
Old 11-27-12, 03:18   #7
thejuiceman
So just some washers and I'd be good to go then, huh?
Do they need to be a certain material (ie aluminum, brass, etc)?
I assume I can use my existing brake lines and hardware?
Old 11-27-12, 11:54   #8
I read Zoran at TWF Racing actually makes spacers for this swap. That's the way to go, washers are a little janky.
Yes, you can use your stock master and the brake lines should be plenty long enough. It's also perfectly safe to reuse all the hardware if it fits, just get new copper washers for the banjo bolts.
Old 11-27-12, 15:42   #9
thejuiceman
Thank you, Sir!
Old 12-07-12, 01:41   #10
1 riktig svensk
1 riktig svensk's Avatar
Send a message via MSN to 1 riktig svensk
I have a complete setup in case you're interested...pondering on parting out a 2009 Daytona.
2008 SE converted to Striple
My Gallery
Find me on Facebook!
