#41 |
That is probably going to friend on the class and it's rules, but for SS it's most likely a multi angle valve job, no port work, and possibly milling the surface
09 Street Triple 06 Track Triple |
#42 | |
And porting is something that post race tech will catch. That's why they pull the airbox. |
#43 |
06 675 .06 head gasket and valves "lapped" in to seal correctly. Not cut.
Arrow Stage 2 pipe, cam timing 107 & 104 kit ecu. Mapped at RM Racing
Scott |
#44 | |
14K RPM? what are you doing for valve springs?
#45 |
Has kit springs and oil pump, I also replaced all gaskets while I had it apart with the 09 gaskets. So the oil pan gasket is the baffle gasket. And 09 are re usable.
Scott |
#46 |
Oh, the red line on the dyno is u4.4 the other is pump.
Scott Last edited by car51?; 11-24-12 at 15:02. |
#47 |
