#11 | |
This is THE Tuning section on THE 675 forum... I can't think of a better place to offer 675 maps
09 Street Triple 06 Track Triple |
#12 | |
Sorry Mac that's a typo on my part. The Wayne map is based off a <29 VIN and my VIN is >38. Not gonna work, huh? Can I just copy and paste the tables?
1997 YZF100R/Thunderace - 12 o'clocked it! 2008 Jet Black Daytona 675 - I called her Tasi!...she's dead! 2013 Daytona 675R - Her name is Tasa!
#13 | |
I have done the copy/ paste thing before. IT works, but its certainly not preferred. I did it to get a starting point and hopefully save dyno time.
#14 |
Just loaded this on my 06 with a Jardine slipon. SO much better than the TOR map with the timing from 3-6 copied to 1/2. Much quicker, FAR smoother at low throttle, and less jerking in the 4.5-6k range cruising.
#15 |
Yah, it does run really well with that map. I've noticed that the fuel mileage is a little lower though if that makes a difference to anyone. I think I'll try loading the newest tor map, once it gets warm again, and then compare the two.
#16 |
To bring this thread back to life.
I am almost done putting my bike back together, just need to get an exhaust leak fixed and get the side fairings back on. I did upload Dave73's tune onto my bike and am amazed how awesome a custom tune is on a bike vs. the generic triumph tunes. Just for comparison sake I had the TOR tune with my jardine and K&n filter and had several flat spots and the bike felt very inconsistent. Now I have merge collector and full 2" exhaust, k&n, 1 stage colder spark plugs, and 02/cat/sai/air flapper/evap removed and WOW is the only words that come to mind. I know I have done some work before going to the new tune, but this thing flies. Did a few 1st gear pulls just to get the bike to stretch its legs after the long storage and the front wheel lifted! it never did that before with the stock gearing and scared the shit out of me. The bike idles smooth and no check engine lights (except the air flapper which has been fixed). Can't wait to get it on the dyno and see if it needs any tweaking
1993 Mitsubishi 3000GT VR-4 2007 D675
#17 |
This thread is a great idea, can't believe it hasn't gotten more response and only 1 tune actually posted to it.
I'm heading to Hord Power this Saturday with 2 2012 675R's for dyno tunes on both of them and I'll post both here when they're done. I can't believe there's not a base tune for a full "Stage 3" Arrow exhaust for my bike....Hoping I can help others out with that. My bike will be tuned with: Arrow Stage 3 full exhaust BMC race filter Intake flapper delete SAI delete O2 disabled Exup disabled His bike will be tuned with: Modified stock header I made him (Cone merge collector, no Cat, no Exup) K&N Filter Intake flapper delete SAI delete O2 disabled Exup disabled I'll add VIN numbers and crap when I post the tunes. Excited to see how my home made exhaust stacks up to the Arrow on back-to-back dyno runs! I think its going to fail miserably though unless he adds a slip on of some sort....stock muffler for now. |
#18 | |
#19 | |
My bike did pretty much what I expected it would, 118.3 hp, 52 ft/lbs. I know all dyno's are different so peak numbers aren't important, but the before/after was amazing! JD Hord did a great job smoothing everything out and gained 14 hp and 4 ft/lbs over the baseline run. For some reason the tach pickup was going nuts and there were huge spikes in the torque curve so he didn't print it out. But here's the before and after runs: ![]() When I get a chance I will read the map out from the bike and upload it here in case someone else wants it for a baseline. My buddies bike just didn't perform like it should. It was way down on power and we were all baffled, couldn't find a reason why. After the tune it was only at 104 hp and it just died after 12k rpms. Not a fuel issue as a kinked fuel line was my first thought but it wasn't running lean and the line was good. I might make a post on this later to see if I can get some thoughts from everyone else and pick ya'lls brains a bit. |
#20 |
What year is his bike? If it is 09 and newer check the clutch switch. If it is not hooked up or is not working it will be down on power as you have described.
Slow is smooth, and smooth is fast |
