20000Km & All valves in spec. - Page 2 - Triumph675.Net Forums
Old 11-23-12, 00:51   #11
crash&burn
crash&burn's Avatar
Wink Good workshop
Originally Posted by 2BRacing View Post
Hi
Would you mind giving the name of the shop you used? I must admit I am also wary of the dealer, but they did a R/R replacement under goodwill in April - long before the bulletins, so I am still prepared to use them for 40,000 km service coming up.
Thanks
40000km is also a B service if I am not mistaken so its also shims etc, etc. Triumph w/shop mgr told me not to expect much change from R4500 for the B service, since I do everything except valves, throttle sync, & plugs, that is all I needed to outsource. Danie Maritz racing 0215565914 got the nod, <R2000. Check out their website or better still go & see for yourself.
The other good one is Superbike solutions in Som west.
''You win some, you lose some, you crash some''
Old 11-23-12, 13:52   #12
2BRacing
OK cool, thanks for the info c&b, I will check those 2 out.
Old 11-23-12, 15:59   #13
lola
lola's Avatar
Good to hear Crash&Burn. Over here we have a guy/shop that does Spectacular work on triumphs but he's backed up with work for at least 3 weeks as we speak...
Martin, If all turns out well on your bike maybe you could give my valves a look as well
Old 11-24-12, 14:15   #14
ANZAC
ANZAC's Avatar
Great to hear
I had my valves checked at 12k and all were fine except for two exhaust that were barely out of spec. If you take care of your engine - let it warm up correctly and don't beat it to death you should be fine. I will probably not need anymore adjustments in the future.
He has Risen
