20000Km & All valves in spec. - Triumph675.Net Forums
post #1 of 14 Old 11-22-12, 07:28 Thread Starter
crash&burn
crash&burn's Avatar
Thumbs up 20000Km & All valves in spec.
I am so impressed with this bike, at the 20000 km B service after 3 years ownership from new & countless track days not one valve needed shimming. New plugs were fitted, BMC air filter washed, oil (fully synthetic) & filter changed. Throttle bodies were also OK. Only repair was to the bush on the clutch lever that I didn't even notice was worn.
The bike shop that did the work also prepares race bikes, the facilities are spotless & their work meticulous, all the things the local Triumph dealer is not.
I am considering a recommendation to fit a "Power comander" but will see if I race the Street or get another bike for that purpose.
''You win some, you lose some, you crash some''
crash&burn is offline
post #2 of 14 Old 11-22-12, 08:13
Orangeman
Orangeman's Avatar
Question...why would you pay the premium for a Power Commander when our ECU's are programmable and the TuneECU software to do it is free. Costs all of about $10 for the proper patch cord ?
.. My Bike.. ...has a new owner :(
Orangeman is offline
post #3 of 14 Old 11-22-12, 09:27 Thread Starter
crash&burn
crash&burn's Avatar
Umm because I am not that good with a cell phone never mind Tune ECU
As always, I appreciate your advice though O/man, I must look into this, maybe the guy just wants to sell Power Comanders.
post #4 of 14 Old 11-22-12, 10:37
Polystigma
Polystigma's Avatar
Fingers crossed this is the case with mine. I am opening the bike up tomorrow. Already have a shim kit on hand from, Hot Cams. Hopefully I won't have to use it.
Also going to try my hand (first time) at using TuneECU to synch my throttle bodies. May also re-flash to the latest Arrow 3-1 map. I think I may have an older map, but not sure.
Would also have to reset TPS, and reset adaptation if I remap, correct?
Polystigma is offline
post #5 of 14 Old 11-22-12, 11:12
Orangeman
Orangeman's Avatar
Yes sir...always re-set the TPS as your last step after doing ANYTHING ..
Just remember after you are done everytihg else to hit disconnect in the TuneECU program, turn the ignition off....wait until the bike finishes dialing the mother ship....turn the ignition back on, re-connect TuneECU, then do your adaptation re-set.
post #6 of 14 Old 11-22-12, 11:15
Tronix
Tronix's Avatar
Is that what I hear? lol
Bike: 2012 Triumph Street Triple R - My youtube channel with my videos
Car: 2012 MazdaSpeed3 JBR TIP SRI | Damond OCC | COBB AP | Stage 1 S-OTS 93
Tronix is offline
post #7 of 14 Old 11-22-12, 11:44
Bamboo671
Bamboo671's Avatar
What's the harm if you don't let ET phone home and then do the reset? I've always just turned the bike on and let it run until the reset TPS turned green.
Sent from my DROIDX using Motorcycle.com App
1997 YZF100R/Thunderace - She committed suicide 15Mar07!
2008 Daytona 675 - She was murdered 30Jan13
2013 Daytona 675R - Sexy reincarnation 15Mar13! Here's my build
"The process is more important than the product" - Inky Johnson
Bamboo671 is offline
post #8 of 14 Old 11-22-12, 12:09
Orangeman
Orangeman's Avatar
When you shut it down and let it go through its re-set in preparation for the next start you are absolutely sure that everything is at its proper zeroed starting position which is what you need for a correct TPS/adaptation re-set.
post #9 of 14 Old 11-22-12, 14:40
2BRacing
Hi
Would you mind giving the name of the shop you used? I must admit I am also wary of the dealer, but they did a R/R replacement under goodwill in April - long before the bulletins, so I am still prepared to use them for 40,000 km service coming up.
Thanks
2BRacing is offline
post #10 of 14 Old 11-22-12, 16:11
toronto675
toronto675's Avatar
As a fellow luddite first i learned to use a pc then use it to tune my bike using tuneecu. Not hard just take your time .
Sent from my GT-I9100M using Motorcycle.com Free App
toronto675 is offline
