[Track] Really fast corners and throttle... - Triumph675.Net Forums
Go Back   Triumph675.Net Forums > Daytona 675 & Street Triple 675 Global Forums > Riding Skills
Riding Skills Tips, lessons, experiences, etc. Beginner, intermediate and advanced.
Old 11-22-12, 04:44   #1
Ricardo_
Ricardo_'s Avatar
Default [Track] Really fast corners and throttle...
What do you do with throttle control before facing those REALLY fast corners, which still provide full lean angle & knee down?
1. Roll off (just a little), keep it steady, then turn?
2. Not rolling off and keep the throttle steady, then turn?
3. ???
Thanks.
Old 11-22-12, 05:21   #2
WiK1d
WiK1d's Avatar
Option 1.
Roll off a little, neutral throttle, tip in, hit the apex, pick the bike up and whack it open again.
It does depend on the corner speed though. Some you will keep the throttle pinned, some you will have to roll off a little bit.
www.bertusras.com | @bertusras
'07 Derbi GPR125 2T | '07 Triumph Daytona
Old 11-22-12, 06:13   #3
Ricardo_
Ricardo_'s Avatar
by neutral throttle do you mean keeping it stactic/steady when you roll off just a little, or a hair open when you (almost) completely roll off?
Old 11-22-12, 07:37   #4
WiK1d
WiK1d's Avatar
Just keep it open, but not wide open.
This might help a bit: http://www.youtube.com/watch?v=oH7JuzgRgp4
Turns out I'm not actually doing what I'm saying I should be doing. Thus, do whatever feels the best for you.
I'm rolling off much more than I thought. (0:18 and 1:40 marks)
But in the end you want to have power on the rear wheel to maintain chain tension across the top to create anti-squat.
Edit: Somebody stop me if I'm talking shit
Old 11-22-12, 10:30   #5
louie3
louie3's Avatar
Maintenence throttle.
come join TheClymb http://www.theclymb.com/invite-from/LouieBruno
"Life is all about maximizing experiences and minimizing regrets, and the last thing you want is to regret the experiences you didn't have." -MadMel
Old 11-22-12, 10:52   #6
WiK1d
WiK1d's Avatar
That's the word I was looking for
Old 11-22-12, 12:18   #7
StayAwakeAtWork
StayAwakeAtWork's Avatar
I don't feel steady in any corner under 6000rpm. So I match my gear for the speed so that I can keep it above 6000 the whole way through, going neutral for downhill, slightly positive for level ground (to account for friction lowering speed) and trying to increase throttle as I'm headed through an uphill turn.
The Wood-Paneled Daytona675 thread:
http://www.triumph675.net/forum/show...338#post850338
Old 11-22-12, 13:10   #8
tooblekain
tooblekain's Avatar
Send a message via AIM to tooblekain
For track riding if you can maintain 10k RPM you're in the good range...you can drop down to 8K every now and then; but once you go below that the bike has essentially fallen flat on its face and will take longer to get back to the power band.
Ride and get shacked in the Tube....Kain the Throttle
What is The Clymb? Click on the link below and be prepared to be hooked:
https://www.theclymb.com/invite-from/tooblekain
Old 11-22-12, 13:26   #9
Ricardo_
Ricardo_'s Avatar
what does steady means anyways? maybe i'm having problems with english because it isnt my mother language.
for me: steady on throttle = stactic on throttle = not moving your wrist = neutral throttle = maintenance throttle = not rolling on/off
right?
and when you say ur "slightly positive", does it means increasing throttle+increasing lean angle? isnt this wrong?
Old 11-22-12, 16:08   #10
Rink675
Rink675's Avatar
right?
I don't know if it's "wrong" to add throttle and lean at the same time but it is the most common reasons for crashes. I have done it on accident when I was first learning throttle control and never crashed but it was on mild street riding and I wasn't in the high RPM range either so it would make it more difficult for the rear to spin up on me.
I think at some point you are either maintenance throttle while leaning or slightly rolling on because if you have a decreasing radius turn and you have to tighten up your line the throttle still needs to be there to keep the suspension working properly.
Just my thoughts on that anyway.....could be wrong.
2007 Triumph 675 Race Bike
