HeliBars TracStar Handlebars for the Triumph Daytona 675 - Page 2 - Triumph675.Net Forums
Old 11-20-12, 18:50   #11
chinoamigo
chinoamigo's Avatar
hey TJ
bought these from you a while back for my '12 675R, had a shop install them and they told me they had to manipulate the angle of the brake reservoir to make it clear the fairings, and the included bracket did not fit, though I'm not sure if the helibars came with a different bracket. i guess they changed the reservoir in the newer model years, so the instructions were outdated. is this normal?
Old 11-20-12, 23:16   #12
Kaosu
Kaosu's Avatar
Originally Posted by chinoamigo View Post
hey TJ
The R has a full Brembo system on the front. The reservoir and brake lever are completely different from a standard 675 and the reservoir mounts at a different angle. I don't believe the manufacturer produces brackets for the R's. Most people just make a homemade bracket.
Sent from my Galaxy Nexus using Motorcycle.com App
Posted using 100% recycled electrons!
Old 11-21-12, 09:41   #13
Thanks Kaosu. I should have specified earlier that I haven't had a single complaint with the standard 675's. The R does use a different master cylinder so you might have to get creative on the reservoir mount, but the rest should be plug and play.
