How to remove intake flapper valve - Page 3 - Triumph675.Net Forums
Go Back   Triumph675.Net Forums > Daytona 675 & Street Triple 675 Global Forums > Maintenance and repair > How To's
Old 05-14-12, 06:27   #21
Caspian
Always thought the squeak was the exhaust valve
Old 05-14-12, 13:57   #22
Bamboo671
Bamboo671's Avatar
Send a message via Skype™ to Bamboo671
If by exhaust valve you mean EXUP then that noise is more of a whining noise when the motor kicks on. The flapper sounds like a whistle or a chirp to some.
1997 YZF100R/Thunderace - 12 o'clocked it!
2008 Jet Black Daytona 675 - I called her Tasi!...she's dead!
2013 Daytona 675R - Her name is Tasa!
Old 10-21-12, 23:58   #23
dannyboy263
dannyboy263's Avatar
Im trying to do this to my bike, so how can I see the pictures, not very forum savvy so How do I bump? and also the hoses that go to the black canister on the radiator, do i remove them all and as well as the canister?
Old 10-22-12, 07:33   #24
Cel675
Cel675's Avatar
on my to do list. Post pics
Cel81XtremeStunts-MichiganFaction.com
Old 10-22-12, 13:27   #25
dannyboy263
http://youtu.be/Znns7T54oJs
here is the vid thanks to Tim.
Old 11-10-12, 17:21   #26
sirhosis of deliver
Nice one.
Old 11-13-12, 23:12   #27
Dewilmoth
Just a heads up on what worked and didn't work for me (2011 675R). I started by just changing the RPM to 900 in TuneECU. That kept the valve open when I started the bike in neutral, but when I dropped it into gear it would close and function just like it was stock. I then disabled it using the check box on the left side of TuneECU (still 900), and it now stays open all the time. I suspect that some of you changed the RPM to 900 and saw that it was open in neutral and called it good. Check to see if it actually stays open when you put the bike in gear. Either that or my bike is somehow different.
Old 11-14-12, 08:49   #28
sirhosis of deliver
SO you unticked it?
Interesting, as I thought that box was to be unticked if you wanted to remove it the flap without throwing up a CEL fault, where as to modify when it opened you changed the RPMs as you did, yet that didn't work if in gear?
The bike couldn't have possibly dropped below that 900RPM limit once in gear could it?
Old 11-14-12, 11:33   #29
Dewilmoth
Yes, I un-ticked the intake flapper box.
It was idling rock steady at 1250 as always, and wouldn't open until 4500 when in gear, just like stock. And I know the 900 RPM tune was downloaded to the bike because when it was on the stock tune it was closed at idle in neutral.
