Custom Built Full Exhaust On The Cheap - Page 13 - Triumph675.Net Forums
Old 11-11-12, 12:06   #121
KEGSdale
KEGSdale's Avatar
Originally Posted by TheKyleRC View Post
Is it not possible to just cut the stock header right after the 3-2-1 merge? Instead of having to do the merge yourself.
Sent from my iPhone using MO Free
IMO, if you're already doing the work to remove the exup, might as well get rid of the stock collector as well. Look at the 2nd pic in my original post, any true 3-1 collector is going to out flow that. It helps too if you have fabrication skillz, it cuts down on the cost you have to pay others to cut/fit/weld. But even if you have to pay someone to do it, I know of others who have had this done for around $100 bucks plus parts, which really isn't too bad.
If you can rely on your ability, you don't have to worry about reliability.
Old 11-11-12, 12:39   #122
Bamboo671
Bamboo671's Avatar
Send a message via Skype™ to Bamboo671
Do you think this job could be done with an arc welder?
1997 YZF100R/Thunderace - 12 o'clocked it!
2008 Jet Black Daytona 675 - I called her Tasi!...she's dead!
2013 Daytona 675R - Her name is Tasa!
Old 11-11-12, 17:29   #123
krause95
krause95's Avatar
Once the exup is removed wont it set off the warning light or no?
Old 11-11-12, 17:53   #124
Bamboo671
Bamboo671's Avatar
Download TunECU and get the correct cable and you can disable it in the tune you use and clear any error codes you have.
Old 11-12-12, 01:15   #125
TheKyleRC
I am doing a custom side exhaust for my street fighter - the pipe will be fairly short so wouldn't the bad flow help cause a little back pressure that it'll be lacking otherwise?
Old 11-13-12, 07:18   #126
tp555
The smallest dia pipe in the system will determine back pressure if it is a continuous system. If you have a chamber depends on whether the outlet is in line or off to the side.
Old 11-13-12, 14:15   #127
KEGSdale
KEGSdale's Avatar
I can't see bad flow helping anything. Even when you buy a full shorty exhaust like a Zard for example, they all use true merge collectors.
Old 11-16-12, 07:22   #128
Cel675
Cel675's Avatar
got my header and cone parts. going to get this rolling.
Cel81XtremeStunts-MichiganFaction.com
Old 11-16-12, 08:42   #129
Dave73
Dave73's Avatar
Post pics.
are you going to do a before and after dyno run?
09 Street Triple
06 Track Triple
Old 12-15-12, 21:07   #130
Nitto12Ss
Nitto12Ss's Avatar
Just got mine done today, was about a 5 hour job with the help of my buddy Kevin. I had the bike dynoed on Thursday with just the Akra slip and will be going back this next Thursday to see if anything was gained.
A few pics
What your cutting out
A few of the steps
2009 Buell 1125R (sold)
2008 Triumph 675 (track bike)
2006 Buell XB12Ss (street bike)
2005 KTM 300 MXC
Honey Badger doesn't care!!!
CVMA #78
