Rizoma Grip HELP! Stuck. - Triumph675.Net Forums
post #1 of 20 Old 11-12-12, 19:53 Thread Starter
wiffle32
wiffle32's Avatar
Well, I've got myself into a pickle.
Yes, I tried heating with a blow-dryer.
Had a terrible time stuffing my Rizoma grip left side onto the bar. These are the Lux grips on a 675R.
I lubed the bar with Dow33 and started tapping on the grip with a mallet. I quickly achieved sliding the grip on about 60% and came to a dead stop.
Heating with a hair dryer has not moved the grip and I don't dare smack any harder with the mallet.
Heat gun? Anyone else figure this out?
If it's stuck forever, I'm going to email Motovation and Rizoma and see if they'll comp me a new left side and give it another go. This isn't looking good. I have resolved to accept the loss, cut this garbage off, and call it a lesson.
"Need" is not a word to be associated with owning a motorcycle.
"Need" is a word to describe the desire to ride.
wiffle32 is offline
post #2 of 20 Old 11-12-12, 20:24
wfire19
wfire19's Avatar
Using air compressor is said to help expand the rubber and help it slide on better, I used hair spray and was able to twist and slide mine up the handle bar...
wfire19 is offline
post #3 of 20 Old 11-12-12, 20:34 Thread Starter
wiffle32
wiffle32's Avatar
The Lux is aluminum... and is 24hrs away from a date with a dremel.
wiffle32 is offline
post #4 of 20 Old 11-12-12, 20:59
wfire19
wfire19's Avatar
Is it still not an aluminum body with a rubber sleeve on the inside? i cant speak from experience with the Lux, but thats how my aluminum Driven D3's were
wfire19 is offline
post #5 of 20 Old 11-12-12, 22:20
Knolly
Knolly's Avatar
Can you easily remove the bar? If you can throw the bar in the freezer and keep the grip at room temperature or even heat it up a bit. Pull the bar out of the freezer and shove the grip on.
2015 Ninja H2
2013 Street Triple - Sold - Egotistical Bike Thread
2009 Ninja 250 Track Bike - Sold
2009 Daytona 675 - Sold - Self-Indulgent Bike Thread
2008 Street Triple - Sold
Knolly is offline
post #6 of 20 Old 11-13-12, 00:29
post #7 of 20 Old 11-13-12, 08:42
Knolly
Knolly's Avatar
Oh, misread which order you were doing it, but yeah throw the whole bar in the freezer and pull it out and hit it with a hair dryer. I was only able to achieve something like this except I didn't use a freezer because when I installed and removed my Lux grips it was 10 degrees outside.
2015 Ninja H2
Knolly is offline
post #8 of 20 Old 11-13-12, 11:21 Thread Starter
wiffle32
wiffle32's Avatar
I considered this, but it seems I'd have to take the triple tree apart to get the bar off.
I'm going to tap/pound this thing to see if I can get it off, then send an inquiry out to the appropriate people.
TJ is going to set me up with some white D3's that will work better.
wiffle32 is offline
post #9 of 20 Old 11-13-12, 11:40 Thread Starter
wiffle32
wiffle32's Avatar
Got the grip off fairly undamaged. Crisis averted... time to give a WTF to someone.
[EDIT] - Motovationusa said they knew it was a problem on some Daytonas. As a courtesy, I expect to get a return label via email. However, they do know I pounded on it pretty good... haha
wiffle32 is offline
post #10 of 20 Old 11-13-12, 13:28
Godly
Godly's Avatar
I'm no help in your OP problem, but i'm just saying, I HATED my D3 grips. Uncomfortable and a half IMO. I swapped to Renthal Medium's and couldn't be happier, and they still look great!
"Faster we become, until the thrill of speed overcomes the fear of death"
Godly is offline
