#2821 |
I second this - their website isnt fantastic, but the quality of their work is seriously impressive, and well worth the wait. Certainly worth firing them an email, and seeing if they can sort you out
#2822 | |
Sent from my iPhone using Motorcycle.com Free App |
#2823 | |
![]() Join Date: Mar 2011
(The stock sprocket cover still fits over it and you can barely see it) As a side effect it tightened up the shifter action without making it any firmer/harder. . |
#2824 | |
#2825 |
I'm not a fan of turn signals integrated in the tail light. I believe it's a lot more difficult for people to notice if your turn signal is on or not. Not to mention, it won't legally pass safety inspection here in VA because the signals have to have 6" between the left and right turn signals.
#2826 | |
As for the six inches between left and right, you can make a case (since the lights in the tail light themselves are over 6" I believe) that since the last LEDs to the left are six inches from the last LEDs on the right, you meet that requirement. But I'm obviously not going to sway your beliefs and you're probably right about not risking running afoul of VA laws. You don't need that hassle. Guess you'll just have to find some smaller signals than what you've got now. |
#2827 |
nice tail tidy..may I ask which model? Thnaks
2009 Street Triple R 2007 Buell Firebolt XBR12 |
#2828 |
Competition Werkes, painted black.
#2829 | |
Maybe I'm reading it wrong but I find your opening statement condescending and bad form. Fact is that the integrated tail light is only DOT legal as far as the brake light in concerned. The Turn signal function does not comply and there are many instances of states that have vehicle inspections for bikes rejecting them. In a state like VA that has tough inspection laws its best not to risk it. Better to not have signals at all because they are not required then to have signals installed that don't comply because if they are there, they must meet inspection requirements. Virginia Motorcycle Safety Inspection Rules and Regulations 19VAC30-70-360. Motorcycle lights: headlamp, rear, signal, warning. "Signal lamps installed on the rear of the motorcycle shall be red or amber and shall be located on each side of the vertical centerline of the motorcycle as far apart as practicable but not closer than nine inches, measured from the optical centerline of the lens, and shall be located on the same level and not less than 20 inches above the ground level. " . |
#2830 | |
Oh yeah ... that is what i'm going to fit as soon as the shifter shaft is replaced. Apparently the Sato Shift shaft support is a little hard to get though.... The shifter shaft is also unavailable here in AU, so it has to be ordered in from the UK... which means a long wait for it to arrive. No riding until it's fixed... S.
"Just because you're breathing, doesn't mean you're alive" |
| Thread Tools | Search this Thread |
