#121 |
IMO, if you're already doing the work to remove the exup, might as well get rid of the stock collector as well. Look at the 2nd pic in my original post, any true 3-1 collector is going to out flow that. It helps too if you have fabrication skillz, it cuts down on the cost you have to pay others to cut/fit/weld. But even if you have to pay someone to do it, I know of others who have had this done for around $100 bucks plus parts, which really isn't too bad.
If you can rely on your ability, you don't have to worry about reliability. |
#122 |
Do you think this job could be done with an arc welder?
1997 YZF100R/Thunderace - 12 o'clocked it! 2008 Jet Black Daytona 675 - I called her Tasi!...she's dead! 2013 Daytona 675R - Her name is Tasa!
#123 |
Once the exup is removed wont it set off the warning light or no?
#124 | |
Download TunECU and get the correct cable and you can disable it in the tune you use and clear any error codes you have.
#125 | |
Sent from my iPhone using Motorcycle.com Free App |
#126 |
The smallest dia pipe in the system will determine back pressure if it is a continuous system. If you have a chamber depends on whether the outlet is in line or off to the side.
#127 | |
#128 |
got my header and cone parts. going to get this rolling.
Cel81XtremeStunts-MichiganFaction.com |
#129 |
Post pics.
are you going to do a before and after dyno run?
09 Street Triple 06 Track Triple |
#130 |
Just got mine done today, was about a 5 hour job with the help of my buddy Kevin. I had the bike dynoed on Thursday with just the Akra slip and will be going back this next Thursday to see if anything was gained.
A few pics What your cutting out ![]() ![]() A few of the steps ![]() ![]() ![]() ![]()
2009 Buell 1125R (sold) 2008 Triumph 675 (track bike) 2006 Buell XB12Ss (street bike) 2005 KTM 300 MXC Honey Badger doesn't care!!! CVMA #78 Last edited by Nitto12Ss; 12-17-12 at 02:51. |
