1050 throttle tube installed! - Page 2 - Triumph675.Net Forums
Old 10-29-12, 20:09   #11
I don't really notice much of a difference on the street with mine. Until I go to WOT, then it's big grin time!
Trinity's Mod Thread
Old 10-29-12, 22:19   #12
Forcereal
Forcereal's Avatar
On the track I was always late to wide open(always had a few mm left after apex), now I'm getting there easier, more often, and quicker. My rear tire really tells to story.
For the money and ease of installation I think it's worth a try. If you don't like it take it off.
08 D675- track duty currently street
98 M3- daily/auto-x
07 D-Max 2500- recovery vehicle, bike hauler
Old 10-30-12, 00:44   #13
Swift_R
haha ok ok ok you guys are talking me into this.... time to call up triumph dealer! :D
Old 11-01-12, 00:20   #14
pyroking339
pyroking339's Avatar
It's a good idea. You'll be glad you did it.
Old 11-10-12, 15:02   #15
jason68278
jason68278's Avatar
Hey all, I just installed the speedT tube on my streetT and it is not retuning the closed postion any suggestions?
"Just dreaming about doing wheelies"
Old 11-10-12, 17:27   #16
Have you adjusted the cable length? If you run out at the lever end you will need to get under the airbox to make adjustments.
Old 11-11-12, 18:15   #17
jason68278
jason68278's Avatar
Thanks, I had to adjust the adjuster nut, on the return cable.
Old 11-13-12, 20:13   #18
dannyboy263
dannyboy263's Avatar
So decided to go ahead and get some Rizoma grips, has anyone tried this and how are they?
Old 11-14-12, 20:51   #19
Evan_Calgary
Just installed this. Wanted to confirm that to keep the return cable as much slack as possible you want the adjuster as close to the throttle side as possible correct? Seems like there isn't a whole lot of slack before it starts to rev...
Old 11-15-12, 03:39   #20
The 1050 throttle tube has a larger diameter than the standard one, so almost certainly you will have to slacken the throttle cables in order to fit it.
