Stock STR only needs regular 87 octane gas. The Arrow 3-1 lowboy exhaust being for offroad/race applications with different ecu mapping, does it now require premium gas? I don't see anything mentioned in the Arrow instructions.
2013 Daytona 675R 2012 Street Triple R 2013 Diavel AMG |
Depends on which map you use. It's not about which exhaust you run, it's about the ignition changes in the map itself. All the available maps have a fuel requirement in the description.
Nuno!
Noodles Racing would like to thank the following sponsors for their support in the 2012 CSBK season: GP BIKES TRIUMPH, EUROCORSA PERFORMANCE (Bitubo suspension, Spidi leathers, Rizoma rearsets, Power Bronze windscreens), ARMOUR BODIES, MOTOAIRBAG CANADA, MOTOVAN, HINDLE EXHAUST. http://s21.photobucket.com/albums/b294/Noodles_771/ |
It all depends on the quality of fuel on your bike's individual needs. You always want to run the lowest grade you can without combustion detonation. I've been able to run regular on my Street Triple with the Arrow 3n1, Daytona cams, Daytona full Arrow map. It runs great with regular fuel as long as it's not hot out then I need to run plus or premium.
The owners manual call for 89 octane, so I use 89 octane.
As others have said, if you are not changing the ignition timing, changing the exhaust places no new requirements on your fuel. I tend to follow the idea MacBandit puts forth, running 87 during the winter and 89 during the summer here in Atlanta.
#7 |
With my bike I can only use 91 octane . If not the bike is a tad sluggish and the mpg is kinda sh!ty . And when I price it out and compare it to mileage it's pretty spot on relative . 87 octane the bike runs a little off and I get 105 miles for 3 gallons . 91 octane I get 130-140 and she's responsive . I run TORs and a sport map with California sh!t gas from all the additives .
#8 |
Every bike is different and fuel quality varies station to station and region to region so find what works. I can get 160miles before hitting reserve on regular pump gas with Daytona cams, full system, and map on my Street Triple so as they say your mileage may vary. Run what works. Pay attention to your bike and it will tell you.
#9 | |
Every and I mean every bike is different as much as they look the same. Start with 87... it's the same quality as 93, just different firing properties. Listen to your bike and "she will tell you", to quote our friend!
#10 |
if you have the triumph map from the dealer for that pipe there are fuel spec requirments listed with the map and the tech should be able to tell you which map/fuel requiremnent you have. mine uses 89, and thats what the owners manual calls for ,thats what i run.
