A bit of advice.
So .......... I have read so many posts on this board relating to dead batteries, electrical problems with no idea what the battery voltage is, etc. etc. Invest in a simple $35 Tender, keep it plugged in and many of these problems will no longer be an issue. Your battery will certainly appreciate it. ![]() I have 6-bikes in the garage and they are all on a Battery Tender....it's part of owning a modern motorcycle, just like chain lube, regular fluid & coolant changes, and a good stand.
Currently in the garage: Daytona 675 2006 (2 each) Bonneville 904cc 2003 KTM XC-W 250 2009 Honda CRF 230 2008 Husky TE-250 2010
If you buy a lithium-iron battery, you could probably get away without a tender. Have let it sit for 2-3 weeks before, and the voltage drop is insignificant.
#3 | |
Ride and get shacked in the Tube....Kain the Throttle What is The Clymb? Click on the link below and be prepared to be hooked: https://www.theclymb.com/invite-from/tooblekain |
Since when has modern technology dictated that I need a tender to maintain reliability?
Of course on the other side of the coin, I bought a bike new in 2003 and sold it in 2009 with 75000 klm on it. Original battery. Never had a flat in 6 years. You don't necessarily need a battery tender if you ride it regularly enough. How many of you have battery tenders hooked up to whatever you drive on a daily basis? I suppose if you have a riding season due to the climate, only do track days or are only able to get out on your bike once a fortnight for a ride, then it may be a requirement. |
#5 | |
Battery Tenders are like condoms
I don't let anyone else ride my toys and I have commited to them all, so I shouldn't need that level of protection.
#7 |
My recent post about battery life was not related to the battery unfortunately :(. More than likely my stator went bad...
