Custom Built Full Exhaust On The Cheap - Page 12 - Triumph675.Net Forums
Old 08-21-12, 16:06   #111
KEGSdale
KEGSdale's Avatar
Originally Posted by Logans08Daytona675 View Post
What I want to know is that were you able to get a tune done on this and have it run well>? No flat Spots and other problems.
I had it dialed in pretty damn good just using Tuneboy and making changes myself and testing it over and over. Never had the time to get it on a dyno or I'm sure I could have gotten it a lot better. I had all the flat spots worked out though. Next setup I build I will definitely have it dyno tuned.
If you can rely on your ability, you don't have to worry about reliability.
Old 08-21-12, 17:40   #112
jamesepoop
Niiice, do you have any high res pics of your bike? Absolutely love this low mount.
Old 08-22-12, 16:22   #113
KEGSdale
KEGSdale's Avatar
Unfortunately, not any good high res ones of the exhaust side. Got some of the other side though. I parted that bike out awhile back after spinning bearings in 2 different engines. I've got an 08 SE now and I'm going to be building another header/low mount exhaust here pretty soon.
Old 08-22-12, 18:15   #114
Logans08Daytona675
Logans08Daytona675's Avatar
Thanks Dale
Old 11-06-12, 20:48   #115
krause95
krause95's Avatar
Just ordered my stock header today. Going to make this a good winter project but have some questions. I am planning on getting a coneeng collecter and putting that on and just welding in some SS pipe to get rid of the cat and run that on my comp werks undertail exhaust... but here are my questions.
A) What if I kept in the o2 sensor? would it help the idling problems you guys were having and/or help performance at all?
B) If I were to keep in the exup in that should keep the volume down at idle right but would it be worth the fab work to integrate it into the SS pipe ? also if I did this (keep the exup) would it take away most of the performance gains?
Old 11-07-12, 13:01   #116
KEGSdale
KEGSdale's Avatar
A) I removed mine since the exhaust is so short, but with you having an undertail I would probably keep the o2 and have them weld in a bung for it. With such a short exhaust the readings it was getting were not accurate.
B) Don't under any circumstances, keep the exup.
Old 11-07-12, 23:11   #117
krause95
krause95's Avatar
haha ok i'll chop her off! what are the negatives about it though?
Old 11-09-12, 17:15   #118
krause95
krause95's Avatar
Anyone out there know what size O2 bung to get and what threads?
Its for a 09 Daytona O2 sensor
Old 11-09-12, 20:36   #119
TheKyleRC
Is it not possible to just cut the stock header right after the 3-2-1 merge? Instead of having to do the merge yourself.
Sent from my iPhone using MO Free
Old 11-11-12, 00:21   #120
Dave73
Dave73's Avatar
You can do that but you won't get all the benefit of a merge collector
09 Street Triple
06 Track Triple
