Which steering damper? - Triumph675.Net Forums
Go Back   Triumph675.Net Forums > Daytona 675 & Street Triple 675 Global Forums > Modifications > All Things Suspension
Old 11-04-12, 22:11   #1
Desmoto
Default Which steering damper?
Hi, which damper would you guys recommend for my 07 race bike. Been looking at the Scotts, Gpr & titax. Any pros & cons on the different ones would be much appreciated.
Old 11-04-12, 23:10   #2
shouldnthave
shouldnthave's Avatar
Scotts. That is the only damper you should ever put on a bike. In my humble opinion.
675R dedicated track bike
My BOTM thread.
Old 11-05-12, 00:45   #3
Smoke
Smoke's Avatar
My Hyperpro "active" in the OEM position does the job just fine, not intrusive at low speeds and not killing any feeling when the going gets rough. Some say they need to loosen the mount before they can use their front stand hooking under the triple tree. I wanted to keep the tank area clear for its bag.
Don't forget the bike shouldn't be so squirelly that it becomes unmanageable most of the time, if that's the case, perhaps you should work on your setting, or you're being too forceful with the steering, I didn't have problems with the OEM one, you can just try to put thicker oil in it, just wanted to have it adjustable, and used the occasion of a Group Buy...
Old 11-05-12, 13:22   #4
Tasman
Tasman's Avatar
do not chaige the oil in the oem damper it will only mask the problem. crashed broken my arm with it. you dont know how bad it is until you use a good damper. i was so stupid not to chainge the oem damper. now i have i hyperpro rsc top mount does the jop all the way. i used to have head shakes all the time and i thought it was normal. it wasnt.
i can feal the hyperpro when it works. the steering makes the move and the moment it starts it stops their.
Old 11-05-12, 14:32   #5
sittingturbo
sittingturbo's Avatar
I love my GPR, have had no issues with it.
Old 11-05-12, 14:36   #6
dubguy85
I have a pitbull. I like it a lot.. Fits great, works great, looks great.
Old 11-05-12, 21:48   #7
shouldnthave
The problem I have heard with the Hyperpro and all other top mount liner dampers is: it will most likely not survive a high side. I have never witnesses the aftermath with a HP in a high side, but I was told not to get one if you didn't want to also replace it along with the rest of the damage, by several AFM racers.
As for the Scott's: not only is it bullet proof, but it has three adjustments. One for low speed, one for high speed, and one for pitch.
Lastly, when I was extensively researching dampers I discovered the Scott's dampers are almost never returned unlike other less expensive reproductions.
My BOTM thread.
Old 11-07-12, 02:02   #8
Tasman
Tasman's Avatar
Hopefully i will survive.
Old 11-07-12, 02:09   #9
So who do you work for again?..
2010 TornadoRed D675
Old 11-07-12, 07:15   #10
Cel675
Cel675's Avatar
lool
Ive had scotts and gpr. Both are good imo
Cel81XtremeStunts-MichiganFaction.com
